Full Version: Wiring loom needed/passenger window stuck open...
Hi guys
I cant post this in the 'for sale' section yet as i dont have enough posts Confused
My passenger window wont go all the way up and many of the wires in the loom on the drivers side are corroded and have snapped, it worked if i pulled the wires toward me but now i think the wire has finally snapped. There was no loom cover from the frame to the door and I can see someone has had a go at repairing them before with various random bits of wire, solder and electrical tape! So im going to bite the bullet and get a whole new loom....
I saw Dangti6 is breaking a 306 in Somerest or if anyone else has a loom i can buy at an affordable price that would be good
I have a 306 HDI phase 3
Can anyone suggest a way to get my window back up in the meantime???
Cheers ThumbsUp
Remove door card and power the motor manually with some wires. Leave up until you can get a wanted ad or get down the scrap yard
Just put 12v (from a battery or whatever) across the two pins on the window motor (or whatever pins they connect to on the switch) to put the window back up - connecting the positive and negative one way will lower the window, the other way will raise it.
Awesome thanks for your fast responses! Off to do that now before it rains again!
All sorted in about 10mins just ran a bit of wire directly from the car battery, unplugged the loom connection from the motor and fiddled around until it went back up
For future ref positive battery terminal connects to near side motor terminal and neg to offside motor terminal for window up Big Grin ThumbsUp
