Ive a problem with my dturbo when I try and brake my car it takes very long to stop and they feel really spongy, what's the problem I've tried to change the brake fluid etc?
Have you bleed fluid from the rear as well as the front? Also the rear brakes if there are drums may need adjusting
Lots of possibilities.
First inspect all the brakes, ensure nothing worn out and no leaks.
Then as said, properly adjust rear shoes if you have drums.
Then bleed them from back left then back right then FL then FR. (furthest from the MC first)
Check the vacuum line as well as like mine cracked
(10-09-2014, 05:17 PM)clarkey2010 Wrote: [ -> ]Check the vacuum line as well as like mine cracked
No problem thanks for all the help guys
