26-08-2014, 03:35 PM
26-08-2014, 10:39 PM
Don't know the part number but know they were fairly easy to find on service box or if not sure the pug parts desk will find them easy enough
01-09-2014, 07:12 PM
(26-08-2014, 10:39 PM)rocker8742 Wrote: [ -> ]Don't know the part number but know they were fairly easy to find on service box or if not sure the pug parts desk will find them easy enough
tried that local peugeot dealer all he could find was early spoiler that bolted through rear screen.
01-09-2014, 08:33 PM
Try taking the spoiler to a local diy store and test fit a few screws?
01-09-2014, 08:54 PM
Grind the lugs off and use tiger seal instead. Jobs a good'un.
04-09-2014, 06:38 PM
(01-09-2014, 08:54 PM)WiNgNuTz Wrote: [ -> ]Grind the lugs off and use tiger seal instead. Jobs a good'un.
found some correct thread in homebase
05-09-2014, 06:08 PM
Did you have fun drilling the holes? I ended up drilling too high at first and ended up with 1cm holes after i corrected it
12-09-2014, 07:53 PM
(05-09-2014, 06:08 PM)Iceman299 Wrote: [ -> ]Did you have fun drilling the holes? I ended up drilling too high at first and ended up with 1cm holes after i corrected it
it was ok used double sided tape masking taped to spoiler, pressed against tailgate and d/s tape stuck to it i poked holes in tape before i stuck it on.
