What is the best way to get these snaprings out as they have no lugs so normal circlip pliers are no use. I have in the past cut them with a dremel and using a screwdriver to prise out but its easy to leave scores on the drum
Big socket from other side and tap it out
Im talking about the snapring not the bearing mate
Sharp punch and hammer. One or two good hits will split it. Then re-new
Cheers I eventually got it out with sharp chisel, damaged part of the drum where the snapring sits but feck it. Cheers
Doesnt matter if its a little damaged.
