Can anyone recommend any products or methods to getting that squeaky clean and shiny exhaust tip.
Autosol metal polish works well
1500 grit wet n dry then autosol
As above, autosol....but don't get it confused with anusol...
(12-08-2014, 09:06 AM)cully Wrote: [ -> ]1500 grit wet n dry then autosol
Sand paper cleans everything.
(12-08-2014, 10:07 AM)silverzx Wrote: [ -> ] (12-08-2014, 09:06 AM)cully Wrote: [ -> ]1500 grit wet n dry then autosol
Sand paper scratches everything
EFA[/b]
technically so does polish
1500grit is fine, unless they do 2000... either way, that, and a little autosol will do the trick
You can get 2000 and finer. It's easy with a polishing head on a Dremel, use it on my inlet.
Degg bought a 2 step metal polish yesterday. Worked really well on my tip.
Does that stuff cut through surface rust?
My tip cleaned up nicely with some 1600 and loob. Just that surface rust/crud
Well deggs tip is covered in soot and that came out nice. Neither of the was rusty tbh.
