30-07-2014, 08:33 PM
Selling the GT2056S that I purchased and rebuilt last year and have used for approximately 13k miles at 1.6bar. (First 5k only at 1bar)
Originally removed from 2.8 Iveco
Comes with all you see in the pic, the gaskets and original exhaust side plate and a exhaust supply 4hole plate which I used to adapt the turbo for my needs. Also comes with the 2.5" tight 90degree bend which is often needed when fitting these to a XUD of some sort.
No MBC, but the wastegate will hold 23/24psi.
Coldside cleans/polishes up nicely. Oil seals all still perfect. Thrust bearing no movement. However the main bearing has more than the usual play with very slight scoring on the cold side. Its still boosting well as you all know, but I want to be honest. Wants a rebuild. Please see the video for the play
[attachment=18052]
[attachment=18053]
[attachment=18054]
[attachment=18055]
[attachment=18056]
And the video:
£30 posted without the 90degree bend
£35posted with it
[attachment=18052]
[attachment=18053]
[attachment=18054]
[attachment=18055]
[attachment=18056]
And the video:
£35posted with it
