Got a phase 3 spoiler to go on my t reg dt, whats the best way to put them on? Was initially going to tiger seal it but there doesn't seem to be much contact area for it? Was going to drill holes but not sure what screws/bolts to use!
What do you lot rekon?
Cheers!
Does your DT have a ph3 bootlid? If so, it'll have the holes on the inside already, you just need to drill through the outer bit. You can just use long screws, the standard ones are T20 Torx but doesn't matter tbh.
Yeah has the ph3 boot with the holes inside which will help! Are they screws self tappers or just normal threaded ones? Also how long will they need to be? (sorry for all the questions ?)
Can get the original screws from pug for not very much can't remember the part number though so not very useful lol
I probably some i can measure for you if you get stuck?
6925 C2 is the part number.
'5-50' is the only detail, not sure if that's length!?
That will do nicely, cheers!
