13-07-2014, 05:20 PM
13-07-2014, 05:39 PM
They don't look that bad tbh, I've seen much worse! Usually from cars that live in towns and have to park tight against the kerb.
As for things likely to be f*cked, probably lots lol...
13-07-2014, 05:41 PM
They clearly park by feel instead of using conventional methods.
13-07-2014, 06:02 PM
(13-07-2014, 05:39 PM)Toms306 Wrote: [ -> ]As for things likely to be f*cked, probably lots lol...
Its a Ford Tom, so yes.....
But anything specifically related to scraping your wheels against every kerb you see....
13-07-2014, 06:14 PM
Depends... If it's just a slow parking scrape it shouldn't do any harm. If it's drifting round corners and hitting kerbs it can do all sort of suspension and steering damage lol...
14-07-2014, 09:12 AM
Interior looks pretty decent for the miledge.
I'd be banking on at least having to replace both front suspension arms.
14-07-2014, 07:01 PM
I does look tidy and wheels are just cosmetic.
I dont wanna spend too much though, I think itll be too much when it finishes!
14-07-2014, 07:22 PM
I can't see it going for much more than a grand tbh, they just don't hold value as theres so many around.
14-07-2014, 07:56 PM
A large amount of that is corrosion, initiated by kerbing. Common for Ford wheels with raised lips it seems.
Kerb it, lift the paint and the lacquer and the rest of it falls off. You'll note that it follows the raised castellations around the rim of the wheel, then stops on each spoke generally.
