09-07-2014, 02:54 PM
Up for sale is my Hispec front brake setup. Selling due to an upgrade.
This is a complete package for sale. Brakes, mounts, pads, discs and braided lines
Pads and discs are both Pagid with no more than 4k on them so plenty of life left in them. Lines are custom made HEL lines in blue. Callipers are painted Hammerite gold but some paint has come off due to a leaking bleed nipple (replaced and reseated and now perfect)
Brand new slider pins fitted as old ones were seized.
This setup will bolt straight up to a standard hub, no modification required and uses standard 6 discs. It should fit under cyclones with a 20mm spacer and will fit under any 16" and above wheels with ease.
This is a great setup, very light and does pull your face off under hard braking. Pads are the same type as used in a Volvo 240 and are very cheap (my last set cost £9). Brakes flew through the last MOT with no imbalance or power issues.
I'm after £300 for the whole setup and can post at your expense but am happy to bring these to Ace or potentially come and meet you for a bit of diesel money.
Will upload photos later
