Air bag light has been on for a while
But on the way home from fcs the abs and stop light came on
Abs fault
Air bag faults
any help will be greatly appreciated
The airbag faults will be related to the dodgy pretensioner cables under the seat. Pm cully for some of his resistors or have a search for how to do it yourself.
ABS is the rear wheel sensor, replace with new
I'm not sure that it the ABS sensor? Looks more like the ABS unit at fault unless I'm reading it wrong?
Says right hand rear wheel? Sounds sensor related to me!! lol
Right hand rear wheel inlet/outlet solenoid valve...the valves are in the unit that stop or allow fluid to give the brake pumping effect.
That is the problem of generic fault codes lol. PP would be the way to go tbh.
When I searched that code on google it said it was a switch for the break pedal ?
Search long enough it gives about 5 or 6 different things lol.
Get some proper diags on there and try again.
