As title please...
im looking for a 205 diff for my conversion so i can fit the 306 gearbox into my 205
thanks all
steve
please message me with offers
You don't need the diff to fit a 306 box into a 205;
Pm me if you're stuck..
Better to use the 205 diff IMO as Steve can then use 205 shafts without having to worry about inner CV's.
what Dan said.
I have a BE diff at home but I think it may be the bigger planet gear type as its from an Expert van, will check later if I remember, I do have a 205 diff but it needs planet gears.
(27-05-2014, 12:36 PM)Dangti6 Wrote: [ -> ]Better to use the 205 diff IMO as Steve can then use 205 shafts without having to worry about inner CV's.
the 205 shafts matched with a 306 box never caused any issues for me? What worry is there with the inner CVs?
the larger diff from the Turbo gearbox doesn't allow full engagement of the shaft, meaning the LH shaft is compressed that bit more and the seal can also leak.
ok thats maybe where my confusion has come from, thanks
I have a 205 diff
are you coming to fcs/pugfest?
(27-05-2014, 06:26 PM)td_dan Wrote: [ -> ]I have a 205 diff are you coming to fcs/pugfest?
i dont go to any car shows tbh, thanks
Ok well i can sort you a price posted if you want?
yes please, i was only in lichfield yesterday too lol closer to you than i am when at home lol
Awww man you couldve collected lol, i can save it until your up here again if its easier i dont mind either way
i wont be for a while i dont think i was picking my new seats up, what would you be looking for the diff please mate?
Is the td 205 box/diff higher ratio than the NA diesel
Its a longer ratio box I think mate
Thought so. When I drove the other one back from yours it wanted to be in a lower gear all the time
Just bang the one in from the green one into yours. Along with the cooling system. As your ones a bit ropey
And engine
I'll build up the other one with hdi rods mls gasket ported and polished etc then whach a vnt and my Bosch on afer i blow up my current one with a td04
Ive got a diff sorted out now, but still looking for a set of complete 205 shafts still
