Ok so i fitted my turbo now it sounds bit like a police siroen with no boost but the reek is pure black not a bit of white could it be a boost leak ?
sounds like it.. all gaskets new on the inlet/pipes? it would have to be a pretty hefty boost leak break out the soapy water and give all the pipe joints a spray, rev the engine gently, if yous ee bubbles you have a leak..
i would suspect that something is open completely or left off somewhere however
Lol
Have you got a boost gauge to see what it's boosting?
Is there any play in turbo?
Let's hope inlet/exhaust gasket isn't leaking or you will have to take turbo off again
No play in turbo and hope not like and boosting 0 psi
If there is 0 psi something's not right even a blowing gasket still should register some boost made sure the boost gauge pipe is on properly or if it's split
Tryed everything think needs another turbo
Have you connected the pipes properly? Lol
Ok the turbo im gettingg is a k14 has manafold and all the pipes still
hopefully goes straight on
