Full Version: Diagram Needed!: Main Engine > Chassis Loom Plug
The lower right engine bay plugs that connect chassis loom to car - anyone got a pinout for these?!
All the diagrams just show the wires going straight through, absolute nightmare! If not I think I'm just going to have to get an original engine loom and bell the entire thing out!
need more info!
car/engine/rpo number
should be able to help once back from work
2000 P3 GTi6 if possible. I'll try and get an RPO - but should be the very last incarnation of the GTi6 at a guess.
I've looked on Autodata to no avail, so if there is anything I'd love to see it!
Assuming it's the same as my gti I have a diagram in the car Smile
Ohhh, if anyone suceeds I need one for a ph2 1.6 TU 306, can get number, Smile
Cullys your man for that Darren Smile
http://peugeot.mainspot.net/wiring306/tu3jp-l4.shtml
should imagine that'll cover most of the wires.
1co2a and 1co2b are the two plugs, 23 and 14 pin black.
if you want any spacific cable route/number/loocation i could get that to
as a circuit drawing and layout Wink
just a quick throw together may not be 100% correct
[attachment=16380]
IC102A
pin----number---------description
1-M444/6790
2-1070: engine stalled information (BSI)
3-C051
4-220: reversing light control /
5-CC1
6-123: control heating lambda sensor B upstream catalytic converter
7-426/9001: Low Intersystem / Can bus
8-100(1081): solenoid control
9-460(6780): Engine selection position (A)
10-400-9000: High Intersystem / Can bus
11-401: coolant temperature signal
12-410: low oil pressure information
13-140: supply by power relay on engine fuse box
14-414: Oil level / signal
15-415:Oil level - signal
16-B090
17-141: supply of BSM (engine relay unit) by double injection relay
18-120: supply of BSM (engine relay unit) by double injection relay
19-411: oil temperature signal /
20-465
21-7101: Variable power steering command
22-
23-435/B078: Fuel gauge GPL info
IC102B
1-608: Right-hand front window command
2-8061: Cooling water temperature unit command
3-8055: air conditioning regulation control (ac/th)
4-1234: compressor relay control (AC/OUT)
5-
6-6071: Passenger window lowering command
7-
8-820:immo signal
9-821:immo signal
10-822:immo signal
11--
12-430: min. fuel level information
13-4318
14-
By the way - meant to say thanks for this!!!
Hey Cully,
I see many threads about wiring diagrams and they all seem to point to you as the source of all knowledge, or at least the guy with access to autodata Smile
I'm looking for a wiring diagram that covers all the connections from the XUD in a PH1.
Is that something you could help on please?
I can probs track things down, but that assumes no one has messed with my car previously.
I'm used to Hondas where the whole system wiring diagrams are readily avialable on the internet. I can figure it out, but it's like re-inventing the wheels.
Or if anyone reading knows of the location of the PH1 wiring diagrams, please educate me Smile
beat me to it!
19 pin gti6 connector
140 obd socket (green)
141 obd socket (beige)
480 engine fault light (beige)
401 coolant temp gauge (beige)
M444 permanent earth (yellow/green)
414 oil level gauge (yellow)
415 oil level gauge (green)
410 oil pressure warning light (yellow)
465 vehicle speed sensor (yellow)
426 rev/tacho speed (red)
411 oil temp sender (red)
CC4 airbag control switched live (grey)
C120 Reverse light switch (grey)
220 Reverse light switch (orange)
123 lambda switched live (grey)
1070 Alternator warning light (dark brown/red)
400 Coolant temp gauge (white)
100 Starter motor switched live (thick white)
120 fuel pump switched live (thick white)
http://forum.205gtidrivers.com/index.php...pic=114881
