12-05-2014, 11:29 AM
Innovate LC-1 wideband lambda controller and Bosch sensor - £70
Few years old but in good condition, I wrapped all the excess wiring loom up when I installed this, and didn't cut it down, so has plenty of wiring length for almost any installation.
Already has the white 2-pin Junior timer plug fitted to the loom so you can plug it straight in as a replacement sensor for most Peugeot applications.
Also has an extended wire for the reset button + LED warning lamp - I combined them into a light-up button (comes with it) so you can monitor/reset it in the car. I had it built into the dashboard along with the output to connect to the laptop.
Also comes with a copper sheet heatsink for the sensor for turbo applications or use close to the cylinder head, and includes the 3.5mm jack to RS232 lead for reprogramming/monitoring through a laptop.
Off the car, boxed up and waiting for a new home
