Pump has gone on my 6, how easy are these to change? Also, can I get any pump from '99 onwards?
Cheers.
the pumps themselfs are quite easy to change be carfull not to loose the little spacers that space the pump away from the engine mount bracket
you should be able to clamp the pipe from the tank to stop the oil flowing when removing it from the pump the high presure pipe is just fixed via a large nut around the pipe
i think you will need to match the pump up as other 306 have the feed pipe fitting pointing in different directions so may mot be correct for your car
the number to match is printed on the circular sticker oposise end to the pulley
All XU10J4RS pumps are the same, If it's on a Xsara or 306 plus a host of other XU10J4R engine's
I've got a pass pump here if needed
For a six mate? How much posted? Cheers.
