Iv screwed my dturbo running lucas pump and k003 turbo its maxing at 20 psi when i put the foot down i hear a loud sucking noice could this be a boost leak i think car should be boosting more if so were should i look for the leak what hoses ?
if it is a boost leak check around the d seal on the intercooler (where it connects to the inlet manifold) and then where the pipe comes up from the turbo and connects to the intercooler.
"Screwed my d turbo" why do people talk like the makes you sound like a massive chav
But as above check all boost pipes
'Yeaaaar maaan, screwed me dtub, naow its fazter than a prezza'
Anyway...as said, check for obvious boost leaks, D seal for instance, then rip the lucas off and put a bosch on it
Mines makes the same noise but i have a massive air filter, I dont think mine is losing boost.
Ah ok have any of u heard of putting a valve on the pipe of turbo ment to make turbo work more ?
(08-05-2014, 02:35 PM)pbell283 Wrote: [ -> ]Ah ok have any of u heard of putting a valve on the pipe of turbo ment to make turbo work more ?
i'm guessing you mean a manual boost controller and yes, they are popular, let's you control the amount of boost easily . .
Ive got a garret t2 and lucas screwed . From what your saying mines sounds the same. Have you got a air filter fitted lad ?
No airfilter nothing there juat took it out is that why ?
