25-04-2014, 07:29 PM
25-04-2014, 07:36 PM
Tu engine by any chance. That doesn't look bad at all. If it's the Tu engine they condensate in the top rocker due to having a plate in there and oil not circulating. If it's not on dipstick don't worry.
I wouldnt worry about that tbh
25-04-2014, 07:37 PM
Ps means no its not gone
25-04-2014, 07:45 PM
Thank god for that! My heart sank when I seen it. For the sake of £20-£30 I might replace the head gasket at some point. I had no service history with the car so might be worth doing
25-04-2014, 07:48 PM
Itll cost alot more than £20-30 to replace the head gasket, as youll need to replace the cam belt too
25-04-2014, 07:56 PM
Also fluids if you end up doing it. Always worth an oil and filter and coolant change
25-04-2014, 08:08 PM
Yeah when I do it I'll do a service as well will this one do?
25-04-2014, 08:13 PM
Yeah but for £24 I wouldn't trust it. Spend a bit more for peace of mind. There easy to do on it but you wouldn't want to repeat the job
25-04-2014, 08:14 PM
That is just a bit of condensation due to short journeys. If all you ever do is short journeys, it will get worse than that! Wouldn't worry until you start pressurising coolant or loosing it somewhere.
25-04-2014, 08:17 PM
Thanks guys has given me a lot more piece of mind
26-04-2014, 10:29 PM
I'm not insured just start it every couple of days <=- There's ya problem.
26-04-2014, 10:38 PM
(26-04-2014, 10:29 PM)DarkInferno Wrote: [ -> ]I'm not insured just start it every couple of days <=- There's ya problem.
What's the issue?
26-04-2014, 10:50 PM
condensation..
engine never get put under normal load for any period of time, it needs you to sort your insurance out and give it a bloody good driving.
26-04-2014, 10:56 PM
(26-04-2014, 10:50 PM)DarkInferno Wrote: [ -> ]condensation..
Yeah end of May I'm insuring it I need the clutch done at the end of this month so I'm getting day insurance to go get it done so I'll give it a really good drive that day
27-04-2014, 09:24 AM
If you do change the HG, then get a decent brand. The 'cheaper' HGs don't seal well around the oil & water ways, the good ones have the red beading on them (Payen etc). I know from experience!
I got away with just buying the HG on it's own, the exhaust gaskets and bolts aren't much from GSF/ECP. Water pump comes with new gasket too.
Absolute piece of piss to do the HGs on these....loads of room.
27-04-2014, 10:10 AM
(27-04-2014, 09:24 AM)Alan_M Wrote: [ -> ]If you do change the HG, then get a decent brand. The 'cheaper' HGs don't seal well around the oil & water ways, the good ones have the red beading on them (Payen etc). I know from experience!
Awesome thanks I'll have to look out for a payen one
