Full Version: Crystals, Bitron, Aux Bracket, Driveshaft, etc
Pair of crystals, bottom tabs missing and have had the original connectors for the dipped beam cut off and replaced with female spade connectors. Assuming they had HIDs in at some point. £15 + postage
Aux bracket from a ph2 DT. Car was non ac. No idea if it's of any use, just found it in my parts box. £10+ postage
Short driveshaft from a PH2 DT. Probably only did around 5k before I scrapped the car, may be some surface rust on the splines as it's been off the car a year but should come off. £20 + postage
Bitron unit from a Ph1 '6. Was told it was in good working order when sold to me, didn't fit my wiring so couldn't check. £15 + postage.
Got other little bits floating about too like a steering column, gear linkages, spare wheel carrier, etc left over from breaking a ph2 DT. Also have 2 swallow alloy wheels doing nothing.
Bump.
Bump.
