basically car been stood a while when started it there no abs light come on the dash the pump and front discs and pads been changed as well and brakes bleeded but still no good not working any help be appreciated thanx.
Need more specifics than not working, is the pedal up or down, hard or soft. giggidy. What exactly have you done/changed? Did you have any trouble bleeding it? Have you looked over ALL the brake hoses for any splits or leaks?
soft peddle goes up and down abs pump changed and front brakes changed all pipes seem fine seems to be ok to bleed them but no abs light on either when turn ignition on
