07-05-2015, 07:26 PM
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
21-05-2015, 04:57 PM
Had a cracker of a day to make up for all my recent bad luck [GRINNING FACE WITH SMILING EYES] paid a vist to a scrap yard and found myself some bargins!
Found:
• full straight through exhaust hdi
• ph1 glove box
• map light trim
• quick shift
• 2x merc battery cables (same as bmw)
And managed to get the lot for £35 😀😀😀😀😀😀
Oh and also found £2.70 in dashes i ripped apart lmao
Found:
• ph1 glove box
• map light trim
• quick shift
22-05-2015, 07:38 PM
Haha you did do very well on that sump. Really it was a massive thanks to scott as he was the one laying under the car with you in the rain lol. Was a good day yesterday at the scrappy how long till your battery is in the back.
22-05-2015, 07:39 PM
Good effort, what scrappy is this?
22-05-2015, 07:50 PM
(22-05-2015, 07:38 PM)aggyj17 Wrote: [ -> ]Haha you did do very well on that sump. Really it was a massive thanks to scott as he was the one laying under the car with you in the rain lol. Was a good day yesterday at the scrappy how long till your battery is in the back.I dare say after fcs. No more major surgery till after case i make the care undrivable
22-05-2015, 07:51 PM
I'm not exactly sure lol. Justin just rang me up said that they had 4 205's in there lol
(22-05-2015, 07:39 PM)JJ0063 Wrote: [ -> ]Good effort, what scrappy is this?Mattishal
22-05-2015, 07:54 PM
Warmers! Corr good old days down there. Same stock for the last 15 years lol. Used to go there weekly. What ever you buy he says 'EERRRRRR ONE OF THEM, SAY £x' lol
22-05-2015, 07:56 PM
Thats the kiddy! Hes brilliant!
29-05-2015, 07:38 AM
Ok so a couple of updates, been pretty flatout with fcs round the corner. Done a little number on the engine bay changing bolts for the honda style counter sunk allen keys and dashing a bit of yellow in.
Also got hold of some harley davidson chrome spike nuts for the engine cover.
Decided to add a little gay touch of painted lettering on the tyres too
15-07-2015, 09:41 PM
Few pics from fcs
Anyway down to updating this thread back to present. After fcs descovered id managed to shit the engine mount after a nice rolling burnout
So the welding job wasnt to great but shes well penertrated and gonna hold well. Also added a packer to reduce engine sway, have got a baker bm fork bush sat in the glovebox over due fitment.
The only downside of the 7mm plate i deceided to use was the fact it ended up nearly raising the mount an inch as can be seen by how ive attacked the top buffer.
Been craving a battery relocation for a while and had been collecting the bits too. Gathered up a merc battery cable, terminals, eyelets etc for the job. Anyone who knows me will know i like to keep my wiring looking oem so what better way then hiding the possi distrubuter block in the fuse box?
Dislike the look of battery boxes so the battery has liturally been sacked in the boot behind the seats.
Afterwards went back and cleaned up the rust i found in the bay with a fresh lick of diablo
So with the battery in the boot some scrubbing began.... so bye bye bilsteins and hello gaz golds
Decided to splash abit more cash on the underside and treated the car to some powerflex bump stops and exhaust hangings.
Performed a little wishbone rebuild today. Roller bearings had seen better days so set about refreshing them.
Heated the pbush housing with a heat gun and drifted the bearings in with ease
As can be seen by the pic the original sleeve had taken a beaten badly. New were ordered from lynx engineering.
The state of the front bust bearings was insane. Missing a dust cover, balls missing and inner piece set to drop out
These were stubborn to get out but once out were easy to replace. Yet again chose to heat the housing but rather then drift the bearings in with a socket i decided to pull them in with a nut and bolt and washer meeting the outer edge of the bearing.
Once finished was a simple case of refitt
18-07-2015, 08:02 PM
Bit more progress after work. Preparing to fit 195 tyres on the rear to lose my daft stretch up back and gain a little more traction. the only problem was i needed a minimum spacing of 10mm to clear the callipers and there was a huge chance the 195's would rub on the arch at 10mm (currently on 20mm spacers)
So the only logical step i could see was to shave the calipers down.
Kinda think the offsets looking very sory for itself having come in 15mm (sat on 5mm spacers now)
Not a 100% sure on wether i like the fronts poking out now so tempted to take them in 10mm now but will wait till the tyres are fitted up rear
08-08-2015, 07:07 AM
Well couldnt get the wheel to fit after the 195's went on so back to the drawing bored on that note.
So back to business, entered tye car for its mot, genuinley thought it would fail on a long list but the only two things were axel bushes and a brake leak.
After fitting the bushes tried searching for the leak were i had been shown to discover it was only excess fluid from where i had bled them a week ago [FACE WITH TEARS OF JOY]
Anyways so this means that the ph2 crystal head lights passed the mot, was told they were a little hazey but was down to poor bulbs.
Couple of pics from the other night
Found this cargo net in a scrapyard the other day. Bit of a random find to alot of you but was out of my first ever 306 estate. Just brought back abit of nostalgia and had to be fitted how it used to be again.
The only two pics i have of the first 306, died an amazing death at 340k with headgasket failure. Refused to top it up with anymore water one day as it would drink 4ltr in 30 mile then boom, had nipped at shat a rod out the block [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY]
24-08-2015, 08:13 PM
Well found a leaking injector the other day which seems to be one of the many sources of my powerless. Ended up managing to borrow a reaming tool thanks to aggy and re-cut/cleaned the injector seat. Hopefully a perminant cure to whats been a repetavie problem. Anyway heres abit of a crapy vid of her pulling in 4th
https://vimeo.com/137176721
Still got a mystrey boost leak, atm it seems to be a case of cure one to trigger another so really gotta find a way to bead my pipes up and prevent it
25-08-2015, 12:55 PM
Looks very very smart this, lot of love for these estates, I may have to aquire one when I decide to be sensible
Cheers!
06-09-2015, 07:39 PM
So the other day this happened. The car returned to where she started being built to be sat up. Managed to blow bothe the clutch and gearbox at the same time
So once the box was off kinda become obv the damage was internal. Had bought a new box already but the backlash and play in the main shaft was pretty damn extreme compared to the new box!
The state of the clutch just p#@$ed me off. was once upon atime a cg paddle but hadnt expecred it to go yet. The clutch had managed to eat down to the rivets, snapped and shettered the sprung center and snapped the spline center from the body. Aswell as this the flywheels scored to hell and the only savagable thing from my transmission appears to be drive shafts and a clutch fork..... fml
Still watch this space! Dont intend to miss out on pfc expo in three weeks time considering the car made it to the top 40!
06-09-2015, 07:42 PM
How many miles that clutch do? Was 2nd when you fitted it wasn't it?
06-09-2015, 07:47 PM
2nd so no idea before i owned it and has done 40k tortured miles under my foot
06-09-2015, 07:52 PM
That's not bad going on the milage tbf
Yeah.. launched it all the time too. so tbf had this coming
11-09-2015, 08:25 PM
Little bit of an update, aggy has now supplied me with a mint flywheel that just requires minimal wet and drying and the new paddle clutch was ordered yestoday, stage 3 drive torque
11-09-2015, 09:04 PM
Glad I can help out and stop nicking all my pics lmao ;-)
(11-09-2015, 09:04 PM)aggyj17 Wrote: [ -> ]Glad I can help out and stop nicking all my pics lmao ;-)My pic now bitch [FACE WITH TEARS OF JOY]
11-09-2015, 09:24 PM
state of that cg clutch!
you strip a gear out of the gearbox too?
11-09-2015, 09:25 PM
(11-09-2015, 09:24 PM)zx_volcane Wrote: [ -> ]state of that cg clutch!Not 100% sure. Seemed an excessive amount of play of the main shaft though
11-09-2015, 09:33 PM
You'd soon know about it if you'd taken a gear out
12-09-2015, 12:16 AM
Still loving your car bud!
I have a set of four AX GT arches that could be grafted on painted and smoothed if you CBA?
Would take up the gap on the outer rims! Not perfect but...
£15 posted!
(18-07-2015, 08:02 PM)dr_jekyll Wrote: [ -> ]Bit more progress after work. Preparing to fit 195 tyres on the rear to lose my daft stretch up back and gain a little more traction. the only problem was i needed a minimum spacing of 10mm to clear the callipers and there was a huge chance the 195's would rub on the arch at 10mm (currently on 20mm spacers)
£15 posted!
12-09-2015, 04:14 AM
(12-09-2015, 12:16 AM)Redordead89 Wrote: [ -> ]Still loving your car bud!Cheers. I might be cutting the arches out for some large s13 style overfenders
£15 posted!
12-09-2015, 11:25 AM
Don't be using stainless bolts on your suspension struts, they will snap!
