13-03-2016, 12:41 PM
(13-03-2016, 12:06 PM)welshpug Wrote: [ -> ]i'd reshell tbh.
Lol this. Its exactly what im doing with mine. It was getting ropey. Cost me £40 for new motor transfer all the bits job done
(13-03-2016, 03:26 PM)HDi--Power Wrote: [ -> ]Don't be silly and ruin a good turbo over laziness, there is 0% chance of it working as is, take the time and sort it outIts just been such an arse that i cba atm. Already clocked 200 mile on it so damage is already done if its gonna die. Gonna prep this next turbo ready and make a few more mods to get stuff better.
(13-03-2016, 12:15 PM)dr_jekyll Wrote: [ -> ]Didnt ask to reshell tho? Pity if some of you lot worked on old beemers or dubs. Oh no its rusty, f*ck it scrap it and reshell [FACE WITH TEARS OF JOY]
(13-03-2016, 08:19 PM)Danny Wideboy Wrote: [ -> ]Why not weld it up? It's not as if repair sections from scrap cars are hard to come by.Exactly [OK HAND SIGN]
For all the work of swapping the entire gubbins over I'd rather spend a few hours welding what I've got. They are all getting on a bit now so most will need some welding soon.
(13-03-2016, 08:20 PM)dr_jekyll Wrote: [ -> ](13-03-2016, 08:19 PM)Danny Wideboy Wrote: [ -> ]Why not weld it up? It's not as if repair sections from scrap cars are hard to come by.Exactly
(13-03-2016, 08:25 PM)Jonny81191 Wrote: [ -> ]Tbf think the chra died already [FACE WITH TEARS OF JOY] lil bit of white smoke and inlet was smeared with black oil to the point i cant see the colour of the pipe [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY] might be a brether issue again but if not can i get an "i told you so" up in here(13-03-2016, 08:20 PM)dr_jekyll Wrote: [ -> ](13-03-2016, 08:19 PM)Danny Wideboy Wrote: [ -> ]Why not weld it up? It's not as if repair sections from scrap cars are hard to come by.Exactly
Yeah, weld her up[emoji38]
Although I really would sort that CHRA rotation, it's just a wasted effort otherwise.
(13-03-2016, 08:52 PM)Jonny81191 Wrote: [ -> ]I told you soLike everything fella. Its all a huge learning curve. This is my first proper turbo play so considering this seems to be the only error atm i dont think i did to bad. If it was perfect first time id be doing it for a living [GRINNING FACE WITH SMILING EYES] just a humble boy building his toy as cheap as poss on a driveway
Meh, you won't do it again.
(14-03-2016, 09:47 PM)MY95 Wrote: [ -> ]Brembos wont fit under any 15s other than Pro Race 1.2s when I researched this, need a 20mm spacer for clones, theres pretty much no 15's that will fit over brembos, need 16's or above really fellaDamn! Got some clones here i will measure up.
(14-03-2016, 10:48 PM)welshpug Wrote: [ -> ]i'm running 200 bhp on gti6 calipers, and they'll be staying tbh, more than enough till I have lots more power.Im just feeling that once this runs right the brakes are going to be well beyond any good. As they stand now the sliders are in need yet again of a rebuild and looks like the drilled and grooved mtec disks are pretty trashed to.
(15-03-2016, 07:03 AM)Poodle Wrote: [ -> ]If the breather is only an issue when attached to the inlet then you have a restriction upstream that's causing vacuum to draw through more oil from the head. It'd have to be a pretty major restriction to draw that much oil though, is your filter clogged solid?Oil filter?
(15-03-2016, 11:33 AM)Paul_13 Wrote: [ -> ]Think he means air filterI knew that [FACE WITH TEARS OF JOY]
(15-03-2016, 11:38 AM)dr_jekyll Wrote: [ -> ]Now rather than me being a cock this time what sort of chra angle am i looking for and is there any other tips to get this running sweet?
(15-03-2016, 12:10 PM)mr_fish Wrote: [ -> ]Even with the gt15 there not directly on top. Do i just get the most extreme angle i can??(15-03-2016, 11:38 AM)dr_jekyll Wrote: [ -> ]Now rather than me being a cock this time what sort of chra angle am i looking for and is there any other tips to get this running sweet?
Generally Oil feed at the top and and the drain at the bottom so gravity actually helps oil back to the sump so there isn't a build up inside the CHRA.
(15-03-2016, 12:38 PM)Poodle Wrote: [ -> ]The arrangement on the gt15 might not be in line with the engine, but the engine is mounted on a slant in the vehicle. Ideally you want the feed/drain angle to be exactly perpendicular to the ground, in reality it's nearly impossible to get it perfect so try to keep it within 15 degrees of upright.Whats my max angle i can have on the chra then? Might have to look at a new feed line
