02-04-2014, 07:56 PM
Thought this maybe useful to some if...
a) you are fitting twin optic lights and are as tight as me and wont buy a different stalk
b) you have single optic lights, but want both main and dip to be on when you select main beam (some wouldn't recommend this, but I did it with my phase1 and nightbreaker bulbs and all was well for 4years or so)
c)you are fitting rallye blanks, thus want to use a single optic stalk which only has the rear fog light, found on rallyes and lots of Xsaras.
d) you have other plans, like me, for the fogs. thus want to use a stalk with only rear fog on, I found mine on a Xsara. But they are single optic
Tools/stuff required:
Small torx set, for removing cowling and stalk itself
Small screwdriver
Soldering iron/solder
Grease
Time taken: about 10-15mins
Step one: remove stalk from car (I hope you dont need a pic for that!)
Step two: Remove the back of the stalk. this is the part that you put the plugs into. Need the thin screwdriver for this. Lever at the four tabs and it will pop off. Do this over some clean newspaper, in case anything pops out, there are some little tabs/springs
keep the back facing up at this point and make sure no lights are on, as this creates tension on the springs inside. Also worth prizing the two wires from the casing to give you some leeway
Step three:
Turn over the plug section you have just popped off and identify the 'break' in the circuit
This is the single optic board:
This is the twin:
Step four: Using your little screwdriver, lever up the tabs which are not touching so that they are...they solder them together
its worth cleaning off the old dry grease at this point.
Not the prettiest, but it works....you have to be careful not to melt the plastic by the way!!
Then finally regrease the runners etc, I used some white spray grease, and clip it back together
Refit stalk and enjoy main and dip beam on when you select main beam
Small screwdriver
Grease
Step three:
This is the twin:
