02-04-2014, 11:32 AM
pic of rear n/s braike with shield etc removed, what would be the max air gap between the sensor and the rotor "teeth"?? the abs light now comes on as the 2 rear abs sensors are disconnected.... the second pic shows the corroded shields
I will test the sensors for resistance and offer up values obtained....but a spec would be of help.
will test for meter fluctuation when rotor is turned also.........
