01-04-2014, 09:12 PM
As some of you might remember I had a phase 1 black 306 DT running a 9mm bosch, fmic, straight through to cherry bomb, T25 and bigger brakes.
I got rid of it for the 205 but have lost the love and have landed myself with another black ph1 306!
I picked it up with Zak the other day (big thanks buddy) and have just had a look at it today.
(My ref, ignore the below)
Displacement 1.9 L (1,905 cc)
Bore 83 mm
Stroke 88 mm
CID: 116.2 inch^3 | 1904.5 mm
VE: 83%
http://www.centralturbos.com/pop-werks5a.htm
CFM = (1/2 CID x Max RPM) / 1728
(58.1 x 5000) / 1728 = CFM 168.1
CFM 168.1 x VE .83 = "Naturally Aspirated Air Flow" = 139.5
N/A AF * Density Ratio = Turbocharged Volumes of Air
139.5 * 1.35 = 188.3
174.4 / 14.5 PSI = 13 lb/m
Today I had a good look around her and began tidying the bodges the previous owner(s) have left me to deal with. Now I remember why I usually try to buy cars that haven't been owned by young'ans (no offence to anyone but old people take more care with cars).
Firstly it needed a good clean inside so I set off with that.
Before:
![[Image: IMG_4211_zps5ac3bc5b.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4211_zps5ac3bc5b.jpg)
After:
![[Image: IMG_4217_zps6d393497.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4217_zps6d393497.jpg)
Fitted a new fuse box cover (under steering wheel) as last one was cable tied on.
Does anyone know what the brown plugs for that's missing the fuse?
![[Image: IMG_4209_zps1175c878.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4209_zps1175c878.jpg)
Also fitted new covers on both passenger/drivers side foot wells to hide all wiring/cables.
Then got rid of the gay imobiliser thing in the middle:
Before:
![[Image: IMG_4214_zps79b39e64.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4214_zps79b39e64.jpg)
During:
![[Image: IMG_4213_zps50f28bdf.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4213_zps50f28bdf.jpg)
After:
![[Image: IMG_4215_zpsa40ede59.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4215_zpsa40ede59.jpg)
![[Image: IMG_4216_zps9e75dfa5.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4216_zps9e75dfa5.jpg)
Next I stripped out the ghetto sub/amp wiring that was running down both sides of the car and fitted my 6x9's, refitted some side trim/cloth and changed both the rear lights that both had one of the prongs missing and the plastic covers:
Before:
![[Image: IMG_4210_zpse3243254.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4210_zpse3243254.jpg)
After:
![[Image: IMG_4212_zpsad5e69c5.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4212_zpsad5e69c5.jpg)
Here's a little "during" shot/teaser:
![[Image: IMG_4222_zps9907e54d.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4222_zps9907e54d.jpg)
Engine bay is surprisingly clean excluding the hole and related oil/rods/debris:
![[Image: IMG_4218_zps8107a23c.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4218_zps8107a23c.jpg)
The damage:
![[Image: IMG_4219_zps79262755.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4219_zps79262755.jpg)
![[Image: IMG_4221_zps60bff554.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4221_zps60bff554.jpg)
And a few of the bits I have ready to go:
Stack EGT:
![[Image: IMG_4230_zpsad67b51a.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4230_zpsad67b51a.jpg)
Adapter plates:
![[Image: IMG_4229_zps8d8ce7a8.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4229_zps8d8ce7a8.jpg)
Valeo clutch:
![[Image: IMG_4226_zpsdd12a0f3.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4226_zpsdd12a0f3.jpg)
FMIC kit:
![[Image: IMG_4225_zps98b704e0.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4225_zps98b704e0.jpg)
D8A:
![[Image: IMG_4224_zps3003cec2.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4224_zps3003cec2.jpg)
GT2052V:
![[Image: IMG_4223_zps604d9971.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4223_zps604d9971.jpg)
Lastly, I'm having a bit of a dilemma with the drivers seat. It's on a 5 door rail and needs transferring to a 3 door rail, a separate thread regarding this can be found here:
http://306oc.co.uk/forum/thread-22777.html
That's all for now.
Thanks for reading.
Bore 83 mm
Stroke 88 mm
VE: 83%
Quote:Basically it's started with:
- DHY Lucas & T2 with a massive hole in the block
- Lowered on cut springs (90mm?)
- Lowered torsion bar with uprated shocks
- New(ish) brakes all round
- Pressed plates
Quote:Parts in stock that can be fitted include:
- GT2052V
- GT2052S
- TD05-20G
- GT2256V (new)
- TD04L-13T (needs rebuild)
- FMIC kit
- Water meth kit
- AutoMeter EGT & 35 PSI boost gauge
- Oil pres/temp, water temp gauges, inlet temp gauge
- 2.5" mild steel (exhaust / turbo fabrication)
- 205 GTi/RG Steering wheel
- GTi6 brakes
- Strut brace
- Twin slim line fans
Quote:So current spec is:
Rebuilt engine with:
- new waterpump
- new Cambelt
- new tensioners
- new sump gasket
- new ARP head studs
- new Valeo clutch
- Rebuilt DarrenLobb 11mm Bosch pump
- New Bosch duraterm glow plugs
- New oil breather hose
- New inlet/exhaust gasket
- New oil sandwich plate
- New 3.2L TT fuel filter
- GT2052S & K-Type EGT Probe
Other stuff:
- Autometer boost gauge
- Autometer EGT gauge
- Type R Oil temperature & pressure gauges
- FMIC
- No exhaust
- Pressed plates
- S16 seats
- Uprated rear shocks
- Beam lowered 60-80mm
- GTi6 Struts/Shocks 60mm Springs
Before:
After:
Before:
During:
After:
Before:
After:
The damage:
Stack EGT:
Adapter plates:
Valeo clutch:
FMIC kit:
D8A:
GT2052V:
That's all for now.
Thanks for reading.
![[Image: IMG_4261_zps0f055080.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4261_zps0f055080.jpg)
![[Image: IMG_4263_zps4538e173.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4263_zps4538e173.jpg)
![[Image: IMG_4262_zpsdfa8fa53.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4262_zpsdfa8fa53.jpg)
![[Image: IMG_4259_zps9986b327.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4259_zps9986b327.jpg)
![[Image: IMG_4239_zpsacbd57c2.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4239_zpsacbd57c2.jpg)
![[Image: IMG_4240_zps54ef5ecf.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4240_zps54ef5ecf.jpg)
![[Image: IMG_4257_zps612d42b9.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4257_zps612d42b9.jpg)
![[Image: IMG_4250_zps76370a29.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4250_zps76370a29.jpg)
![[Image: IMG_4253_zpsa925216d.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4253_zpsa925216d.jpg)
![[Image: IMG_4254_zps5fa76612.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4254_zps5fa76612.jpg)
![[Image: IMG_4272_zps097750ca.jpg]](http://i467.photobucket.com/albums/rr40/shivannaz/Phase%201%20Pug%20306%20DTurbo%20Reborn/IMG_4272_zps097750ca.jpg)
![[Image: zuhature.jpg]](http://img.tapatalk.com/d/14/04/21/zuhature.jpg)
![[Image: ru4yqeqe.jpg]](http://img.tapatalk.com/d/14/04/21/ru4yqeqe.jpg)
![[Image: egybanu9.jpg]](http://img.tapatalk.com/d/14/04/21/egybanu9.jpg)
![[Image: ybaby7ar.jpg]](http://img.tapatalk.com/d/14/04/21/ybaby7ar.jpg)
![[Image: ejy6equ4.jpg]](http://img.tapatalk.com/d/14/04/21/ejy6equ4.jpg)
![[Image: 8a3u5ysa.jpg]](http://img.tapatalk.com/d/14/04/21/8a3u5ysa.jpg)
