28-03-2014, 01:59 PM
So basically I've spent 2 weeks gettin fecked of with the wipers stopping whee the feel like it on auto!!
So today I set out to fix them
Step one remove the scuttle panel to gain access to the motor? Removing the 2 wipers first 13m socket
Once removed I marked the wiper so it was just easier to place it back together like so
Next was to remove the 13m not, and the 3x10m nuts, careful not to trap fingers when removing the 13m as I did :/ grr!!
There is two bolts 3rd is behind Directly In between the two once done part and you'll be left with this
Then remove the little black wiper plastic thing where the 13m but was, and part the plastic from the actual motor like so
Start by removing the 4 i think there 7m maybe 8 screw, as you can see two already removed, now time to part it like this
Very clean and tidy :/ haha so after inspecting I found this
One of the prongs had snapped half way, so I began cleaning it all up before I attempted repairs
This part I tapped out from where the 13m but was the other side, use something smaller as bit to damage thread once removed clean up using a degreaser, I have a 25 litre tub of tfr, so dropped it in some for a few minutes and was happy with the result
