08-03-2014, 06:44 PM
Well that lasted long
Noticed today that once i warmed the car up, i get a knocking noise similar to a snapped belt tap. It only does this above 1500-2000rpm though which is odd.
My initial ideas are loose/damaged spark plug, cracked exhaust manifold/leak or bad small end bearing (not to convinced on this one as if it was, it would be there from cold and any engine speed). Any ideas?
It only does it when warmed up and above 1500-2000 rpm, is a similar noise to a tapper but does not get louder with rpm, only faster and sounds like its coming from the back or left hand side of the engine.
