06-03-2014, 09:12 PM
06-03-2014, 10:15 PM
(06-03-2014, 09:12 PM)mtbucket Wrote: [ -> ]Hi,
I have a year 2000 306 estate 1.6 petrol
I am looking for an earth strap as mine has corroded a bit
Thanks,
Mtbucket.
Id make one bud. I presume your talking about the Battery Negative Lead to the Gearbox?. I Gutted the old battery leads off an Escort van at my local scrappy (which have vertical tightening 10mm nutts) and crimped/soldered new tags on. Works great on mine :-)
06-03-2014, 10:54 PM
If its not what Phil said then I am lost as to what an earth strap is!
06-03-2014, 10:57 PM
Thanks,
Mtbucket.
You will find they are all corroded now. A new one is about £30 from pug.
07-03-2014, 09:39 AM
Which 'earth strap' do you want? I have one from the Battery neg to earth if that's the bit.
07-03-2014, 09:42 PM
(07-03-2014, 09:39 AM)Alex Wrote: [ -> ]Which 'earth strap' do you want? I have one from the Battery neg to earth if that's the bit.
Hi,
This is the one that comes from the battery area and then splits into 2 down near the gearbox
Thanks.
07-03-2014, 11:21 PM
I may be able to help. Will supply a photo of the item I have.
