Full Version: Possible fuse problems
With the aerial back in place been having problems with the battery seeming to go flat, could this be due to the aerial connection touching the plate?
Also the delay is correct the car started before the needle moved
http://www.youtube.com/watch?v=DylW-BQx2...e=youtu.be
Bad earth somewhere?
Need to get a volt meter on the battery and see what its doing. Worth doing a parasitic draw test as well I spoke.
Seems to have fixed itself after disconnecting the battery and removing all the fuses for inspection (very painful and time consuming), put it all back together and it seems happy now :/
