Loosened both nuts obviously but its not judging. Giving it a good beating its starting to mash it up where it comes tho the engine mount. Anyone any ideas?
(16-02-2014, 01:35 PM)HDIkyle Wrote: [ -> ]Loosened both nuts obviously but its not judging. Giving it a good beating its starting to mash it up where it comes tho the engine mount. Anyone any ideas?
are you 100% sure that you have turned the bolts through 180 as i had similar issues on mine, i had loosened the nuts and turned the bolts enough so i thought but one was still catching so it wouldn't budge.
Ye positive I can see them but even if they had turned back it would come out so far then stop. It's not moved a mm so far its just chewing the bearing up
You need a bigger hammer.
As Tom said, big flat blade/chisel just under the shaft too of the bearing so you don't damage the bearing and mount and smack It with a big hammer will come out
