14-02-2014, 02:00 PM
Not really been on here much but al get a thread up anyway. Started my project thread on the gti6 forum so a lot has been done since buying the car but a quick run through should give you lot an idea of whats been going on. I will let the pics do the talking for now.
I bought myself a GTi6 on new years eve with the Plan to build another track toy again and keep the estate as a run around and work car but after driving the 6 back from Edinburgh i soon changed my mind about stripping it out like my last one and keeping a full interior! Anyway here is when i got it. 1.2s straight on
Got it home New years day and cracked on. Gaz coilovers went on with some adjustable top mounts. Also fitted some new track rod ends and drop links while I was on. Turn in and handling Feels a hell off a lot better now, noticed a good difference. Still need tracking checked tho.
Before:
after:
Come the friday after new year i was back to work. On my way home from work i was heading down the motorway and the belt gave in new engine time along with a load more goodies B)
VLR BTCC Inlet Manifold
Mocal 13row oil cooler
BakerBM group N mounts
BakerBM group A torque bush
Full braided brake lines
AP Racing leaver bias valve
ATE Super blue racing brake fluid
Pugsport alloy axle mounts
Pugsport uprated gear linkages
Cammed engine with mapped ecu -195bhp hopefully
Alloy crank pulley
Lightened & balanced Flywheel
Magnex group n exhaust
Maniflow manifold
Brembo Front Brakes
Aero catch bonnet pins
F1 style mirrors
Brake lines going in
Maniflow and magnex system took from an ex BTCC 306
Somehow ended up with 2 out of 4 know to have been made inlets haha
Engine all cleaned and painted with carbon cover ready for fitting
Inlet cleaned and painted - cam details
Back up and running
Trip to a mates in scotland to collect more bits and help fitting spare rear axle with solid mounts
Then had a little fun with this on my way home B)
Little bored after work so I have changed my clocks a bit. Fitted a phase 3 surround and a little carbon too
Fitted my inlet on my old engine to see how it would fit and see what clearance would be like. PAS relocation kit is needed what I already knew about and dont think its going to fit with the standard rad. Good job I have a 60mm r5 turbo alloy rad. Didnt realise how big it actually is before I fitted it onto the engine.
FINALLY!!!
Weekend just gone i got round to changing my martix . Wasnt as bad as I was expecting to be honest. Took around 2 and a half hours start to finish then an extra hour on top of that to get that stupid break light switch back in what had fell out when we pulled the dash out!!! Also removed the heavy sound proofing from behind the dash as well while the dash was out.
By the look of it the O rings failed on the old matrix
Before:
after:
Alloy crank pulley
Maniflow manifold
Brembo Front Brakes
F1 style mirrors
Back up and running
FINALLY!!!
