306 gti6 front shocks and springs to put on my hdi!
Thanks
Matt
I've some. They have some red springs which would indicate they are probably lowering springs - but I couldn't tell you how low they were. If interested I can look at courier costs, but won't be much.
Yeh sounds good mate if you could let me know please
Got a set of Xsara ones here, and some 306 ones with lowered spring which have covered little milage, just stood for a while, Either set £40.00 delivered
Got some standard gti shocks and springs. £25 posted.
I'll buy those from you underground375
Do you have a 3dr Dturbo HDI?? If so they have GTI spec'd springs shocks & ARBs as standered
ahhh fair enough, it will sit higher than standard with GTI springs , due to the higher weight rating
How much? But surely it will be stiffer tho the one shock on the front of mine leaks anyway so they need changing
UMMM i cant remember , IIRC Dum-dum had them on a HDI estate a few years back if you can find the thread, & i wont be a great deal stiffer , you'd need a GTI front ARB & rear torsion bars & ARB to see any real difference
That's ok, they need replacing anyway I'll slowly build up a gti suspension on the hdi!! Thanks for help
I can always get some hdi lowering springs and put on the shocks
