03-02-2014, 08:34 AM
Changed the ph1 front onto the estate last night, couple of issues.
Firstly, heater blower has stopped working, the motor itself is fine as I had to change it yesterday anyway due to the original seizing up, changed it and had it working until....
Changed the headlights over to phase 1 single optics, used the same wiring loom as morettes, so 3 pin plug to the back of the bulb plus side light connector, plugs into the ph3 plug. Worked once when I tried the lights then had the following problem....
Passenger side, I only have brake and side lights, tried 2 different bulbs, checked fuses, tried a different wiring harness. No change
Since the light issue, like above, the heater blower has stopped working AGAIN
Anyone have any suggestions, I'm hoping I've overlooked something simple, possibly twin optic stalk with single optic lights?
