Ok so I have a bit of a strange one. My current 6 window switch is cosmetically damaged and the button for the drivers window doesn't work. The passenger button and electric mirror part all work. I have purchased 3 different window switches now, told they are working but when I fit to my car they don't. Surely I can't be that unlucky to have bought 3 non working switches? Could there be a different issue? Don't want to keep.buying if they are never going to work
Do they just not work at all now? Might've blown a fuse?
Also is you first one an auto (one touch) switch? I'd guess it would be on a '6?
They don't work at all, but my original works when I plug it back in, so wouldn't be a fuse. The drivers window button has never worked so don't know if it's one touch. My original switch, the passenger button and electric mirror button all work
Ok so just found out a phase 3 switch won't work on a phase 2. So now on the hunt for a phase 2 switch to see if it works
Ah I see.
And yeah, the ph3 ones are usually one touch and the ph2 probably aren't then. I know you can't use a one touch on a car that didn't come with it.
Good luck with the hunt lol.
the early stuf has a seperate controller in the door
later stuff the switch itself is the controller
they ar not interchangable, i believe if you do you blow a fuse if i remember correctly
Cool thanks fully. I've put the original switch back on and it's working, minus the drivers window button
