Deep creaking noise from front after lowering the hdi 60mm. Thought it was the tyres rubbing at first but its not. Wonder if any1 else had this problem? Only over bumps and rough ground, more noticeable at low speeds
Slacken and retorque the front wishbone bolts, see if goes away.
Could be your anti roll bar d rubbers as they in a different place on the bar now as you lowered it
I would second whats already been said, wishbone bushes unhappy about new position or ARB bushes the same
I was thinking the d bush's. Il lube everything up on monday and see whats what.
