I drive a 306 hatchback with 205/40/17 tyres. Could anyone recommend the tyre pressure for my tyres.
Cheers
i'd say 32-35 is a good bet,
Can hugely depend on what sort of roads you drive, EG lots of motorway or also what luggage/weight you carry and also what sidewall strength is like.
35 imo is quite high and would think you will wear the centres out
With a width and profile like that, I'd say 35Psi is probably about right.
Generally 35PSI is too high for normal tyre sizes.
I usually run about 35psi in my 17s. Cyclones are meant to be 35psi
Depends on what tires you use, toyos and rainsports need a few more psi just to stop the tramlining
