Bit of a weird one here.
Just aqquired a HDI with bit of an engine problem.
Starts up fine hot / cold, just as you would expect, but the engine "hunts" or "surges" on idle for first few minutes, does smooth out after a while, but even when fully warmed up, drives like shite, surges on acecleration , like constant on / off power...literally feels like a car with a big 12mm P pump on it or something, only its a stock HDI...
Typically laptop with PP2000 has died, hence this thread...any ideas on whats kicking off?
I'd probably start by unplugging the MAF tbh, easiest thing to rule out at least..
Have already tried that..no effect other than throwing EML
Possibly tps related, test it with a known good one.
Just swapped the TPS fore one i had in the workshop, no reason to believe anything wrong as came from running vehicle 6 months ago, But no change, same symptons
you havnt got old oil in it thats got a bit thick taking longer to get round the engine have you? friend with a fiesta had a simular issue, sounded horrid at first. an oil change sorted it, but the stuff that come out was very thick so wasnt getting round the engine as well as it should untill it was warm and thinned out
Well that is f*cking odd... no ideas above and beyond the stuff already stated tbh. Reset everything by unplugging the battery overnight? Might be worth a try.
Sounds rough as f*ck.
Sudden development or has it been getting worse for a while? Maybe knackered injectors or dodgy frps..?
No idea, bought it cheap as chips (hence the issue) but sure it cant be anything to major....
Have left it dissconnected for 5 mins, is that long enough?
Yeah rough as hell, the idle turns fairly normal as it warms up, but still surges like a bitch when you drive it...
Never seen it myself before, hopefully get PP2000 working later this afternoon and see if there are any codes...wondering if injectors are related...looks like they have "been out" at some point fairly recentl...so someone has been digging, so no idea if there orignals back in or what.. typically my 406 is out on "hire" atm so cant swap, and my scrap hdi hasnt turned up yet
Ah fair enough.
Theres an ecu reset guide I put up thats buried somewhere in the guide section, try that.
Doesn't look theres any smoke, so guess its not burning anything it shouldn't be...
Fuel filter been changed recently?
no idea...no history what so ever...has anyone ever seen these symptons from it blocked? Surely it would just drop RP when running under load / cut out of it was that blocked?
Can't see it being fuel filter, eml would be straight on, and it'd keep cutting out if rp dropped. Ecu reset is a couple of hours iirc.
Tried a leak off test?
Can't say I have tbh and fairly unlikely.. but I guess it wouldn't hurt to whip the top off and see what it's like.. they only need changing every 30k so possible it's not been changed.
I'd check/clean the FRPS too just in case.. fairly weird problem though tbh
Not tried a leak off test no...so thinkign i need to clean FPRS first, then maybe do a leak off test and go from there, still having PP2000 issues atm. I always have endless issues with computers dying in my workshop in the cold heh, and PP2000 is so dodgy at the best of times! bledy computers!
Is it the pressure sensor on the rail that needs cleaning or the regulator itsself on the HP pump?
I was thinking frps (rail), but could be the fpr (pump). I would expect cutting out issues if it was either of those tbh, but for what it takes to check you may as well.
Could you not M-HDi it overnight with your wizardry?
Is it me or doesn't that sound like it's not firing on all, rather than hunting?
Doesn't sound like 4 cylinders as it's pulsing.
That sounds like my mates HDi90 406 did when an injector was malfunctioning. Can't recall if the injector itself was changed or the loom was responsible.
Dont want to M-TDI it, its for my sister, just need it to be oem / reliable heh.
Its not missing entirely on one cylinder, its clearly the ECU changing the fuel delivery all the time, its not a missfire on one pot....not to say the injectors arnt the issue as i know they can cause issues with hdis....
Guess i need a set of poppers, should have another donor here any day so will pull from that I guess.
Darren I have a set of injectors that I know were working when removed, but one had chronic blowby and had a lump of coal plastered round it as a result. I only want a tenner plus post if you want them.
Could well be the injectors, saw similar problems on one of our neighbours cars (Focus 1.8 TDCi) after he ran Morrisons fuel through it which partially blocked the injectors, has more bio in than most iirc.
Does seem odd though, don't think I've seen a HDi that bad, mine used to hunt at idle all the time, hot or cold, but was fine with some throttle.
Have a go at unplugging the injectors one at a time and see if it gets worse. If it gets worse on 3 of them and stays the same on 1 then you have your issue, check the voltage then swap the injector.
I dont think its a good plan to do that, pretty sure you can frythe ECU doing that Chris^^
Uses the injectosr as ballasts i think or something
Just pulled the FPRS out but cant really see theres anything you can "clean"
HAving issues with PP2000, Starting to think it might be my interface causing the issues..
Keep getting the error "Unable to initiate vehicle communications interface"
Tried on 3 laptops now with same issue... If i dissconnect lead i get the cannot find interface message..so its semi working, but im guessing dead? fml...
