21-10-2013, 06:29 PM
All prices are collected, postage would be extra.
Lots more other bits available, car is ready to be stripped as soon as so allow a day or two to remove parts. First come first served. Car is no longer being sold as a rolling shell so all parts to go.
Paypal preferred but fees to be added if not paying as gift.
Wheels:
16" staggered fitment banded steels. 9J front, 10J rear. I ran them with spacers which WILL need arch extensions, but may get away with them with no spacers. Fitted with nankang ns2 fronts with approx 5mm tread and Toyo T1-S rears with approx 3mm tread.
4x108
65.1mm centre bore, direct Peugeot fitment
£320+postage
25mm bolt on hubcentric wheel spacers with shortened head bolts to hub and studs and nuts to mount wheels £50
Engine/Transmission:
DHY bare block, approx. 100k miles £40 collected
Good condition head with new-ish glow plugs, cam, pulley and vacuum pump £30 collected
Phase 1 Nissens ally rad
90A Mitsubishi alternator £30 posted
6PK1145 aux belt, two weeks old £10 posted
Exide Premium 075TE battery, 12 months old, 600CCA, 60Ah. Full of beans, car starts first time every time £30 collected
Clutch assembly £30
Flywheel £20
DT gearbox £30
Miles’ Group N gear linkages (early non-adjustable version, all retaining clips present) £20
Compbrake style quickshifter inc. gear stick £20
GE gearbox-end quickshift £15
Driveshafts £10ea
Suspension
TA Technix coilies, new last month, new top mounts and bearings and both C spanners £130
Wishbones with good balljoints, 12 months old, £10ea
Hubs £15 ea (16mm ball joint, no ABS sensors)
GTi6 rear beam, refurbished 3 years ago, disc brakes, month old TA Technix rear shocks. Torsion bars are free enough to easily adjust ride height, currently rather low.. £170 with brakes, £150 without
Brakes:
302mm 307XSI180 front calipers and flexis with approx. 8 month old discs and pads, only done a couple of thousand miles £100
Rear calipers ok condition but need seals, passed handbrake efficiency at MOT fine. £30 the pair with discs and pads if they don’t go with the beam
GTi6 master cylinder, two port £15
Bodywork:
Not so sure what people will want, it’s a bit unique. Open to offers on any of it though
Interior:
Impreza Sport front seats £30
On/Off toggle switches £1ea
Leaf print leather rear bench (fits 5-door and estate) good condition with head rests £20
Estate folding parcel shelf, no sags, all locating lugs £10
Stereo:
12” sub and amp, nothing spectacular £30
Alpine Type S front coaxials £15
Pm me or mail me at stancewagon@gmail.com if you want anything
Wheels:
4x108
£320+postage
Clutch assembly £30
Flywheel £20
DT gearbox £30
Driveshafts £10ea
Suspension
Brakes:
Bodywork:
Interior:
Stereo:
