Some of you probably know my luck with GTI6 engines and shit luck has struck again.
I split a hose on the way to work and seems as though I've blown the HG again...
So I've decided to xud the thing with the td04 and hdi rods. I'll fix the HG on the 5dr diesel and put the t2 turbo on ice got spare. Swap the 11mm pump for the 9mm too. Put the quaife in the hdi box.
So I'm on the hunt for a base model /diesel fuel for a 205 to get things started
Not bad idea mate...you will see GTi6 power with 11mm n a td04.
And more torque I expect
Run it on veg as well winner all round really
I've had nothing but problems with gti6 engines and I've put up with them for long enough.
Turns out I didn't blow the headgasket luckily so I've kept the petrol engine in.
But i've had soooo much fun and games with the speedo cable and vss sensor of late...
After breaking the original one several posts up, I borrowed one off a freind and the only thing I can think that's happened is that the pin snapped off whilst driving and burnt the f*** out of the plug and then heating up the square link. Causing it to snap.
This then happened to 2 other VSS sensors afterwards and ruined 2 VSS sensors. Should of replaced the loom I know but didn't have a spare loom to hand.
I now have a spare VSS and loom thanks to Cheesegrater. So will try it tomorrow.
Then this happened
The speedo was sticking, quite humourous as when I went above 70 mph it shot up 140 mph [
A trip to see Anthony solved this, many thanks again. You've got me out of the s*it several times recently and i'm very grateful! You're a top geezer.
Gave it a clean as well:
Bad luck with the sensors mate! Do love this car. Still after a nice 205 shell to replace my 306 eventually.
Them speedos are a complete wank!!
This looks sweet though mate, speedline sl434's look an absolute gem on these!!
keep going paul, you will have it up and running!
Transformation to diesel has begun!
Just got to take the driveshafts out and lift the 6 engine out
Then swap the quaiffe diff over to the hdi box I've got to put on.
Bloody difficult working in a council garage! Not a lot of room!
Yes derv ftw! Are you still going to run td04 and 11mm?
Yep there's an 11mm pump on there already, going to look for a gt2056 at some point.
They are pretty hard to find. Teddy had my old gt2052s for sale atm i think. Bought off me then never used it.
Putting a dirty diesel engine in my old GTi - it's nothing short of sacrilege I tell thee!
Still, I guess the GTi-6 boys can breath a sigh of relief that their engines aren't going to be on the endangered list anytime soon if you've ceased blowing them all up for the time being. I suggest the XUD boys buy up some spares while you can though, as if Paul's track record is anything to go by they're going to get thin on the ground pretty quickly...
(02-11-2015, 09:34 AM)powerandtorque Wrote: [ -> ]Putting a dirty diesel engine in my old GTi - it's nothing short of sacrilege I tell thee!
I remember borrowing WVN off Anthony when it was still a 1.6. Can't remember why though.....And now it's going to be a dirty diesel?
WTF is it with you and GTi6's? Hate to think how many alloy Mi16s you'd kill!
Got a replacement td04 to go on, mine has never been as I mustn't of aligned the housings correctly when I built it. The turbine was stuck and then freed off after a bit of persuasion, got a feeling it's f*cked. Was making some awful grinding noises.
Would only max at 30psi. Going to be a hoot with the new one on. Slowly but surely getting round to doing this amongst all the family problems going on.
A few boost pipes need replacing as things have been rubbing on them.
Need to put the quaiffe in the hdi box too
Looking forward to getting this back on the road
Yaaay!
Title needs changing
Title has been changed?!
Just got to put the new td04 in the engine and put it in
In treating project mate,love the sl's one of my all time favourite wheels.
Swap the fuel tank
Swap the fuel lines
put the new td04 on
Swap the quaiffe diff over into the hdi box
engine in and then tackle the wiring which should be a doodle
Tomorrow's job is to convert the hdi box to 205 and fit the diff. Maybe put the gearbox on and turbo
We now have 1 quaiffe converted hdi box ready to go on
Should have the box ready to go tomorrow.
Next job is to clock the td04 replacement, what's the easiest way to get that bastard locating pin out? I was thinking centre punch and drill it out as I don't have a dremel
Think that might of been why my last turbo was goosed, the cold side not sorting true and causing the turbine to get jammed.
I'm thinking of tryng to completely max a 9mm pump including internal mods as I think the 11mm on there is giving funny misfiring/jumpy problem part throttle when warm. Be good to see how they worth and learn a bit
Still need to crack on
