Hi all, i need to replace my near side front fog light as its broken what the easiest way to remove the old one and stick the new one in ?
cheers Gaz
on a ph 3 they are held in with two Nuts and a self tapping screw
you may have to remove the wheel and the arch plastics, at the front to gain acsess, unless you can raise the car then the plastics could be just removed
I find its easier just to remove the front bumper. That way you get the nuts and screw done up tight and its easy.
