I'm after the 2 bolts that hold the caliper/brake pad holder thingy to the hub need them for both sides (4 bolts) any one got some knocking around I can have cheap?
they the same as any other caliper bolt?!
I do have a set of 306 caliper bolts though if needed?
The 247mm bolts are a bit longer when I upgraded to 266mm I had to use a washer to make them fit
(31-08-2013, 09:28 PM)Piggy Wrote: [ -> ]they the same as any other caliper bolt?!
there different on the for the 106 i believe, are yours out of the 266mm brakes?
(01-09-2013, 08:18 AM)Chris_90 Wrote: [ -> ] (31-08-2013, 09:28 PM)Piggy Wrote: [ -> ]they the same as any other caliper bolt?!
You mean the carrier bolts? I have a set of 266mm here you can have bolts if you'd like
(01-09-2013, 08:00 AM)aggyj17 Wrote: [ -> ]The 247mm bolts are a bit longer when I upgraded to 266mm I had to use a washer to make them fit
This if you mean calliper carrier bolts, I did exactly the same
you sure?!?!
I test fitted the 266s to my mrs and all the 106 bolts needed was a washer as already mentioned.
yeah I have 4 carrier bolts from 266 306 brakes.
think i will try the washers then get back to you i just under stood they was to long.
