Full Version: What do I need? Headlight wiring...
I have a set of headlights but no wiring is attached to them, so I need to install the headlight loom so it can plug in as normal?
I'm also trying to fit a hi-lo H4 setup to a ph3 but have it so main beam keeps the dipped on with it so keeping the original stalk.
Anybody have a part number for this?
Cheers
What are you needing a part number for?
(18-08-2013, 01:06 PM)Rich306 Wrote: [ -> ]What are you needing a part number for?
Some sort of cover for the back of the light unit, and the headlight part of the wiring for a H4 setup
Basically the bit thats held in by the cover, has the white block connector then is hidden inside the light unit and goes out to all the plugs for the bulbs etc
The cover for the light unit you can always get at the scrappy.
I know what you're on about regarding the white block, but I wouldn't convert anything within the light unit itself.
Post a photo of what you're trying to attach/convert to?
