02-08-2013, 09:08 AM
What does everyone think of the K&N air filter, Is it worth using one of these over a standard Peueot one? How does the performance and longevity differ to the standard air filter?
Thanks
Thanks
(02-08-2013, 09:31 AM)lolsteve Wrote: [ -> ]I had a universal jobby on mine and while it did sound a lil grunty on the lower rpm range it no doubt didn't do the intake temps any favours since I didn't hook up a cold air feed
(02-08-2013, 09:27 AM)Dum-Dum Wrote: [ -> ]They are good and will flow more but the standard one isn't really a restriction. Also as cully says the oil on the filter can get sucked in and damage the MAF sensor. The reason most people change them is not being able to fit the standard air box with a FMIC.
(02-08-2013, 10:09 AM)MY95 Wrote: [ -> ](02-08-2013, 09:13 AM)ginge191 Wrote: [ -> ]With a DERV; air filters are fairly generic. The bigger the better has always been my call, and often seen the cheaper ebay jobbies are the biggest and often the best. Then again, others enjoy a nice brand on a filter.
Thanks for the reply, so I guess you use the standard air filter? Purflux isn't it?
(02-08-2013, 10:09 AM)MY95 Wrote: [ -> ]Yeah Its probably best as aftermarket "induction kits" get terrible heat soak, like on a 10*C day the standard system will be about 10*C at the MAF but with a induction kit it'll be 30-40*C(02-08-2013, 09:27 AM)Dum-Dum Wrote: [ -> ]They are good and will flow more but the standard one isn't really a restriction. Also as cully says the oil on the filter can get sucked in and damage the MAF sensor. The reason most people change them is not being able to fit the standard air box with a FMIC.
Ok thanks again dum-dum, so you would advise just sticking with a standard purflux one?
(02-08-2013, 10:12 AM)ginge191 Wrote: [ -> ](02-08-2013, 10:09 AM)MY95 Wrote: [ -> ](02-08-2013, 09:13 AM)ginge191 Wrote: [ -> ]With a DERV; air filters are fairly generic. The bigger the better has always been my call, and often seen the cheaper ebay jobbies are the biggest and often the best. Then again, others enjoy a nice brand on a filter.
I don't have a HDi, i run a DT with no filter .. not the best but meh, the noise and spool is epic
(02-08-2013, 10:28 AM)Dum-Dum Wrote: [ -> ]Cant believe your still condoning this after what happened t Max's turbo.
(02-08-2013, 01:17 PM)Piggy Wrote: [ -> ]just watch the pod filter mythbuster on mightcarmods...I put a K&N in the airbox of my HDI. The standard filter was 3 months old so still clean. 2 mpg more and better acceleration. I think they are great.
shows that manufacturers do spend time developing an air box for a reason!
(21-09-2013, 04:03 PM)Arron Wrote: [ -> ]When my car last went on the rollers it pulled 1hp less with the filter off. We put the filter back on and it pulled the same as the first run. Although I dont trust them rollers
I run a hks mushroom filter. It makes a sweet whistle on boost. The inlet diameter is 101mm. The filter is foam like and can be bought for 12 pound as and when needed. But I think it does ruin maf sensors.
The stock airbox modded should be fine tho
