I just need to know what voltage other people's hdi's get at the injectors when cranking? I just put a pin down the connecter on the white wire and the other on earth.
Just will help me sort whether I have a immobiliser fault or not. Thanks.
Says in the other thread - 80v. As mentioned before you'll need a really good mm or a picoscope or something.
You can safely assue they're not firing because the engine isnt running lol.
Yeh I know that that's what it should show in pp2k mate but I need to know what people get with a multimeter.
Its just me and prosteve have been discussing it and are thinking a immobiliser problem. The reason is that when I measure the voltage I get exactly 6.5 with the keyfob and without. Surely it would be different?!
Ah fair, I take it steve reckons the background voltage is an indication the immob is tripping?
Ill try and remmber t try that out for you later when I pop round dad's - havent got my own mm.
Ok Cheers mate, would help a lot.
Seems my brother has got the multimeter this evening, sorry dude.
Do not attempt to run the wngine without the injectors plugged in... It uses the injector solenoid coils as a transformer to step the voltage up and charge the driving capacitors in the ECU, youre likely to cook the injector drivers doing so!!
Also, the injectors should recieve 80v constant, it switches the earth.
Oh really? I thought the injectors received a pulse signal, i need better info lol! Where do you find this stuff dude?
(23-05-2013, 06:21 PM)Poodle Wrote: [ -> ]Seems my brother has got the multimeter this evening, sorry dude.
No problem mate
(23-05-2013, 07:26 PM)Ruan Wrote: [ -> ]Do not attempt to run the wngine without the injectors plugged in... It uses the injector solenoid coils as a transformer to step the voltage up and charge the driving capacitors in the ECU, youre likely to cook the injector drivers doing so!!
Didnt know that either. So what do you think about me only getting 6.5v when cranking and the key at posistion 2??
