What's peoples recommendations. Don't want a light up led shingle just a plain or start button will do. Had one in my hdi but it never worked so what setups do people use that work and which wires under the wheel are clipped into? Cheers
I'm sure grant will come along and give you the reasons why not to use this..
Why's that then? Only for bragging rights really and to fill the hole the fav lighter used to be in. Be cool to have a shine silver button
Sam has one in her car. Works fine.
Massive starter motor though.
(28-04-2013, 02:06 PM)HDIkyle Wrote: [ -> ]Why's that then?
Some pikey wiring led to his cranking itself down the road while he was at work....
Hmm if its pikey wiring I best not have a go myself I was just gona wire straight to the starter tbh
(28-04-2013, 03:01 PM)HDIkyle Wrote: [ -> ]Hmm if its pikey wiring I best not have a go myself I was just gona wire straight to the starter tbh
Just takes one short to start the car then.....
Up to you obviously, but I can't really see the point myself!
I understand it on my Mums car as she has keyless entry and button start, so keep your keys in your pocket/handbag all the time.
But on a 306 you're still gonna need to unlock the door, and put the key in the ignition so it seems like more effort to me.
(28-04-2013, 02:18 PM)SRowell Wrote: [ -> ]This is pretty much all you need to know... Why use one hand to start your car when you could use two!
http://www.youtube.com/watch?v=5FBQwxm0uYo
Them guys are quality just watched a few of their videos been in stitches!!
Bear in mind as well that this will invalidate your insurance if it ever gets nicked
That'll be fine. What I need to know is what kits are actually anygood. The turborevs ok?
Its just a button and a relay. Probably all cheap quality stuff :/
I can vouch for the fact that these should not be fitted....
clicky
Lol!
Quote:More than likely the start button that did this.
I think because of the heat, some of my insulator tape warmed up and came loose, shorting the wires, causing it to crank.
With hindsight, i should have wired the crank button into switch live. But it was 1am when i wired it up.
Itll be fine as long as you dont wire it to a live and insulate it properly. I wouldnt particularly bother. The way they do it in mighty mods is the way it should be done so you have to turn the key and then press the button. That shouldnt invalidate your insurance either as you still need the key!
Aslong as the immobiliser is still present, and you have a battery isolator switch it should be fine. Same concept as using the ignition barrel then. Worth running it by your insurance however.
Would be ignition lived ofcourse.
