Just driving home after buying my newly acquired ph2 lx dt and the electric windows don't work. Neither work off drivers switch and passenger window doesn't work off passenger switch.
Any suggestions as to what it night be please?
door loom will have a break in the wire. mine had 3 broke so changed the loom and its fine. do the switches light up?
Will the drivers door loom affect the passenger switch and vice versa? I'll go check if they light up
yes depending on which wire is broken
on my ph3 the pasanger window and both door mirrors stopped working
Are the broken wires usually easy to see? Could I put a bridging wire in to rejoin them?
all depends what plug you have some plugs are sealed and if the wire is broken close to the sealed plug it could be difficult to get a connection for your bridging wire
but yes bridging is how most do the repairs
And they are easy to spot?
Just checked to see if the switches light up... the passenger one does when ignition is turned on
easy to spot!
yes if they are fully broken once the grommet is peeled back
Do not a door off job necessarily?
makes acsses a lot easyer and door off is only a 5 min job as the door loom is plugged
