Hi. Im having a few problems connecting my lexia to my HDI. Simply getting Ecu has not replied accross the board. The Engine runs, Revs, but has a light on, which shows up as po380, po402 and po220 on my cheap reader. Ive fixed the latter, the tps, by replacing it, as it refused to signal for revs, but the dam lexias the real let down, as it would show up all the probs. Anyone have any clues?. :-) :-) thx
faulty lexia clone or software/drivers not installed
have all the obd socket ports the correct wiring present, on the car pins they have been known to push out the back of the socket
(05-04-2013, 05:28 AM)cully Wrote: [ -> ]faulty lexia clone or software/drivers not installed
The socket is a little loose, but when I try it with the engine running, the speedo moves up and down, like there's coms working. After it tells me ecu could not be referanced, then says coms failed. All the others say no reply. It's as if its either deaf, or doesn't like the fact a bsi isn't fitted. Thanks
Speedo moves up and down? That shouldn't happen...
(05-04-2013, 05:43 PM)Poodle Wrote: [ -> ]Speedo moves up and down? That shouldn't happen...
Thats intresting!!!. It happens with the engine running, but not with just the ignition lights on. Tryed the interface on my dads berlingo, and it did the same, with the engine off. Its as if you can visually see the machine code transfering. Interface is brand new, £60 off ebay, and the guy doesnt deal in cheap, cheap clones. Think its time to get it tested, but where, thats the question
(06-04-2013, 03:48 PM)phil clark Wrote: [ -> ]. Interface is brand new, £60 off ebay, and the guy doesnt deal in cheap, cheap clones. Think its time to get it tested, but where, thats the question
LMAO! @ guy doesnt deal in cheap, cheap clones
as said already faulty lexia clone or software/drivers not installed
(06-04-2013, 04:55 PM)cully Wrote: [ -> ] (06-04-2013, 03:48 PM)phil clark Wrote: [ -> ]. Interface is brand new, £60 off ebay, and the guy doesnt deal in cheap, cheap clones. Think its time to get it tested, but where, thats the question
Lol, well it clicks, and the green lights on. ive changed the software for some known good stuff, with a driver update. Ive been told that some pc's dont like how the system works. The interface was tested prior to it being sent out. Dodgy ground this. ;-)
no more comments good luck!
