what do most do about the original fan connection and triple relay when fitting a slim line fan???
ta for input
im sure there are threads and wiring diagrams up on this already
ok...I'll keep searching....I searched, obviously didnt input the right words!
Well basically you are either going to wire it into existing loom (ie two wires) or make up your own circuit on a switch which was discussed here recently
I want it on current circuit...auto...
but its a single slim line...and theres two originally...
thinking to just use the switched live...earth...via rad switch straight to the fan?
just wondered if others had problems/wrong way to do it
Just use the wires that come from the tripple relays to run a fan or 2 depending on how many fans you had as standard.
To test which is pos and neg pull the temp sender plug and bridge 2 of the pins and theyll start to spinn if they work then you can test them with a multimeter.
My mate wired my rallte up with twin slimlines as per haynes manual twin fan with rad switch. Made a custom loom that worked a treat.
