I'm after a set of dash clocks speedo etc all I want is the trim inside them so I can spray it and swap with mine so want a set of cheap clocks don't matter if they are broke aslong as the trim insert is intact and will go in my phase 2 NAD
I should have the bits of trim your after mate....let me double check later today and I'll get back to you.
Got the inner section here mate, £8 inc p&p
Also got the trim that fits around the outside of the actual clocks unit too if you need it......£12 for both.
I'll post some photos tomorrow for you.
Pics would be good if you don't mind mate thank you
I'll post some later this morning Willo
Photo as promised Willo........
