Full Version: Re fitting steering ram
I managed to get the passanger side rack boot on in the end alot of work but sorted out now.
I had to take the stud nut of for the steering ram piston and nut of on the other end which holds it in place as well also the bracket out the way.
So Im just wandering wats the best way to get the steering ram back on. It was alot easyer to take it of but aligning the nut and bolt up alot harder to get it back on in place.
306 hdi
thanks
No real easy way for someone to tell you how mate. Best think i can suggest is to feed the nut and bolt through the loose ram and just engage the thread, then line the other end up - once both ends are attached drive both nuts down.
