My passenger side window stopped working, hunting thru I've found the issue
The wires in the door loom are all broken,
its the loom when u open the door that's damaged
Any idea where I can get a new/ secondhand 1 from,
Will it be easy to change?
It's a 3door !
Easy to change, just undo the plugs and unscrew the connector from the doorshut.
I have one, PM me.
there should be a guide after the weekend as im doing mine weather dependant
(01-03-2013, 10:41 AM)cully Wrote: [ -> ]there should be a guide after the weekend as im doing mine weather dependant
Guide be useful , good luck let me know how ya get on
I had same problem, rather than change the loom i just soldered in pieces of wire and heatshrunk the solder as it seems to react and then break again if left exposed
(01-03-2013, 11:26 AM)CJ_Derv Wrote: [ -> ]I had same problem, rather than change the loom i just soldered in pieces of wire and heatshrunk the solder as it seems to react and then break again if left exposed
Was hopeing to do that unfortunately where the wire cum away its in the plug
Err!
I just did this on my drivers side pm bigcheez2k3 he sorted me out with my replacement then its just a case of cutting and soldering not that bad a job much easier if you take the door off mind
Are you fitting a new loom to yours?
I need to do both of mine on my D turbo and i have got a pair of 2nd hands that i took off a scrap car but im wondering if it best to buy new 1s
(01-03-2013, 12:28 PM)Willo Wrote: [ -> ]I just did this on my drivers side pm bigcheez2k3 he sorted me out with my replacement then its just a case of cutting and soldering not that bad a job much easier if you take the door off mind
Great help cheers Il pm him
new ones are £97+VAT from Peugeot retail part number 6542 VQ
a lot of money!
(01-03-2013, 04:37 PM)cully Wrote: [ -> ]new ones are £97+VAT from Peugeot retail part number 6542 VQ
a lot of money!
Ouch!
Get a used part to match check how Many pins are in yours first though cos if the don't match you got a really big job on your hands
Ive just done mine. Door off is a definate. Used loom witch was identical just gota get the right wire to each one as there is 2 reds, 3 whites, 2 yellows ect. About 15 wires to join. I cut the block off at one point and a autoelectrian said it would be to big as a job pfft im a gardener 15mins shhhating all done
Hey i found this guide ages ago on google to do the looms .
http://bitsaboutmy306.blogspot.co.uk/sea...-results=1
I have the same problem on both sides i used bt connectors and tape for the moment. I bought 2 looms part number 6542vq which i will use when i have to do it.
(01-03-2013, 04:54 PM)Willo Wrote: [ -> ]Get a used part to match check how Many pins are in yours first though cos if the don't match you got a really big job on your hands
I will check pins, take it just disconnect the plug from the door and count them?
Then check the Replacement loom for same pin numbers
Yeah if you unscrew it you will see how many you have and just make sure the replacement has the same and in the same places
Take some pics too, will make it easier when trying to buy one.
(01-03-2013, 07:50 PM)bigcheez2k3 Wrote: [ -> ]Take some pics too, will make it easier when trying to buy one.
Yea will do, Il post sum over week end
